greenmachineman
Hello Gentlemen; I have a couple questions about my 1949 A that I have taken apart to put new rings in it, and bearings for the crankshaft. The previous owner had a "no maintenance" policy with his farm tractors, so there was about 4 inches of sludge in the crankcase. I decided to take all the oil lines off and remove the oil pump and housing to make it easier to clean all sludge out. I have to order the appropriate gaskets to install these parts now that I have cleaned up them up. I need B251R and B246R. Are these available from other sources than JD? Where I live it is much easier to order them off the internet and have them shipped to me. Also, the upper water pipe needs to be replaced which I know are available. Is it possible to heat up the braze to remove the old one? Or is there a better solution for removing the old? Thanks in advance for any replies, I appreciate the knowledge.
