John Deere A wiring diagram
I have a John Deere A serial #598255 that needs to be rewired. the former owner had removed al the wires from the generator to the amp meter and lights. It has magneto ignition -no grounding stud.
Thanks
Ken
Ken, this diagram (taken from johnnypopper.com) is for a late A, SN 584,000 and up, which uses a distributor, for a Mag theres simply no hot ignition switched voltage lead running to a coil. Its not hard to add a grounding kill switch/stud on some mags (like Wico X) and some even run a wire up (from a grounding stud terminal on Mag) to a dash (On/Off Start/Run) kill switch (key or toggle etc) for safety and convenience. If theres no kill switch or mag grounding stud (even if there is) I prefer to kill them by turning off the gas.
John T
