I appologize if this topic has been brought up a few times before (as I'm sure it has), but I have a few questions regarding the project tractor that I have started on recently.
The engine was loose when I bought the tractor, but it would only turn about 1 revolution of the flywheel and would get tight again. No problem, I figured some junk in one or both cylinders. So I pulled the head, and one cylinder looked pretty good, the other cylinder was a little rough. I went ahead and pulled the block and began honing to try to clean up the cylinder walls some. How bad can the pitting be on a cylinder and still be usable? The pitting is near the top of the cylinder.
Also, when I took the pistons out, both oil rings are broken. I haven't measured the rings to see if the rest are in good shape, but if they aren't, can I buy just the oil rings somewhere, or do I need a whole set of rings? This is a budget tractor that is quickly heading toward over-budget, and I'm trying to keep some costs down.
The last question I have is in regards to the pistons. The engine has been overhauled during the past 73 years, and the pistons are aluminum .125" overbore. Can someone give me a height measurement to tell if they are high compression pistons? Is there some other way to tell?
Thanks,
John
Thanks,
John
