Working on my A when I have some extra time. I"m working on putting the carb back together and was wondering if there is any rough starting adjustments for the load and idle. Need to know also what to torque the head nuts to? Looked in the I&T manual and don"t recall off hand what it said, but I just want to double check. Last question. When changing the engine oil and filter, I put 8 qts in the crankcase. The operators manual says 11qts. Is the roughly 2 qts in the gear reduction cover? on the right side of the engine/transmission and the roughly 1qt in the air cleaner bowl included in the 11qts figure? Thanks in advance.
