4030 pto question 540 or 1000?
2520-4010
07-16-2010 19:01:08
Just curious and can"t remember.....is a 4030 a 540 or 1000 rpm? Or both?
Thanks for the correct reply....
Tx Jim
07-17-2010 04:12:34
 Re: 4030 pto question 540 or 1000? in reply to Paul from MI, 07-16-2010 19:01:08
2520-4010 said: (quoted from post at 22:15:44 07/16/10) That's kind of what I was thinking....just not sure.....in laws have tractor ....couldn't hook up the 1000 bush hog. I guess someone has forgot to leave the shaft with the tractor.
Thanks again.
4030's are both 540/1000 pto rpm's but a 1000 stub shaft wasn't supplied with tractor when new. I know I owned one a few years back that my Dad bought new.
Doug in IL
07-17-2010 17:44:46
 Re: 4030 pto question 540 or 1000? in reply to 2520-4010, 07-16-2010 19:01:08
Some 4030's were ordered as 540 RPM only. I have one of them. The storage hole has a large plug, similar to a large freeze plug installed in it.
buickanddeere
07-17-2010 08:01:57
There was a 1000rpm only version of the 4030. Here a parts list for th 540/1000.
1 R38221 SNAP RING 2
2 AR41752 SHAFT 1 540 RPM
3 JD7557 BEARING RACE 1
4 P50631 O-RING 2
5 R94130 SHAFT 1 (SUB FOR R38224 OR R80744) 1000 RPM
6 R45126 GUIDE 1
7 14H1040 NUT 2 1/2"
8 12H301 LOCK WASHER 2 1/2"
9 R27329 SCREW 2
10 34H348 SPRING PIN 2 3/8" X 1"
Cart KEY PART NO. PART NAME QTY TRACTOR SERIAL NO. REMARKS
11 AR38168 BEARING HOUSING W/O BEARING 1 (MARKED R38218 OR R47507) (SUB RE47805, RE13181, R106866 AND R130561)
12 R33337 GASKET 1
13 R32101 STUD 2
14 R33320 SNAP RING 1
15 R33852 COUNTERSHAFT 1
16 R30319 O-RING 1
17 R33853 THRUST WASHER 2
18 R33028 NEEDLE ROLLER 48
19 R33344 SPACER 1
20 R33339 GEAR 1
21 R42014 GEAR 1 540 RPM
22 R38219 THRUST WASHER 1 540 RPM
23 F1334R SNAP RING 1
24 C1919R SNAP RING 1
25 JD9320 BALL BEARING 1
26 AT16431 SEAL 1 (SUB RE13181, THIS APPLICATION)
27 19H1721 CAP SCREW 4 1/2" X 1-1/2"
12H301 LOCK WASHER 4 1/2"
gregger
07-16-2010 19:05:15
i'd say both should be a snapring holds it in and snapring hold the other right in the back
JD Jim
07-16-2010 19:03:02
Both, just swap the stub.
2520-4010
07-16-2010 19:15:44
 Re: 4030 pto question 540 or 1000? in reply to JD Jim, 07-16-2010 19:03:02
Thanks again.
RickB
07-17-2010 15:05:23
 Re: 4030 pto question 540 or 1000? in reply to 2520-4010, 07-16-2010 19:15:44
The alternate shaft should be stored above and to the left of the shaft in use, just below the toplink anchor. if it isn't there, sometning better be plugging the hole in the rear end housing..... .....
