4430 Mains and Rods
beebelawn
07-13-2010 08:13:39
I've got a early 4430 I acquired. Guy said it had a blowed head gasket. There was no oil or water in it. It had been sitting for several years without either of them. Pulled the head off and had checked, didnt really see anything wrong with it but I coulda missed it. Got it all put back together and started. Run for about 5 mins then locked up. Pulled pan and almost all the mains were galled up and several rod bearings trashed. It had oil while running. What woulda caused the bearings to mess up? Sitting with no oil? Having antifreeze in the oil at one time?
gtx1967jewison
07-14-2010 18:06:40
 Re: 4430 Mains and Rods in reply to beebelawn, 07-13-2010 08:13:39
gee. lets see. sitting with no oil in it. when shut off & sitting all the oil's in the pan. not doing anything good for anything. duh. not the problem.
Heavyduty1
07-13-2010 09:29:55
 Re: 4430 Mains and Rods in reply to Adam Bedser, 07-13-2010 08:13:39
beebelawn said: (quoted from post at 16:13:39 07/13/10) I've got a early 4430 I acquired. Guy said it had a blowed head gasket. There was no oil or water in it. It had been sitting for several years without either of them. Pulled the head off and had checked, didnt really see anything wrong with it but I coulda missed it. Got it all put back together and started. Run for about 5 mins then locked up. Pulled pan and almost all the mains were galled up and several rod bearings trashed. It had oil while running. What woulda caused the bearings to mess up? Sitting with no oil? Having antifreeze in the oil at one time?
It may have been run with antifreeze in the oil before you got it. If the rest of the 4430 is in good shape, it may be worth rebuilding the motor.
beebelawn
07-13-2010 09:49:07
 Re: 4430 Mains and Rods in reply to Heavyduty1, 07-13-2010 09:29:55
It ran good for those 5 mins!! Its not that great of shape but I think I can get it cheap so....
buickanddeere
07-13-2010 13:58:47
 Re: 4430 Mains and Rods in reply to beebelawn, 07-13-2010 09:49:07
It's easy to have 20/20 hind sight but I would have invested in an oil pan gasket. Then looked at the bottom end before starting. The tractor was parked for a significant reason.
