Just started working on my 52 A. Manifold gasket is leaking and I want to replace it. Got the hood, gas tank, water pipe, carb, etc off. Most of the items that I figure would have to come off. The two rear manifold studs came off with the nuts. The front two has stayed in the head and the nuts came off. The governor housing, fan shaft assembly, air cleaner and radiator are still on the tractor. Was hoping I wouldn't have to remove them. Anyways, I have tapped on the manifold some and it seems solid with the two front studs still in it. Was wondering if anyone has had any luck welding nuts to the top of the studs, heating the manifold area around the studs, and then trying to remove them? If this worked then all I would have to do is slip the manifold out the side. Course, I guess if anyone has any other suggestions then I would appreciate it.
