Belt Pulley / JD 1950 Model B
EScottUtz
05-16-2010 14:41:38
The belt pulley on my 1950 B JD is badly worn where the clutch brake has rubbed. Is it possible to have that area bult up and turned down or is there anyone that rebuilds these pulleys? Thanks in advance for your input.
Mike M
05-16-2010 18:29:11
 Re: Belt Pulley / JD 1950 Model B in reply to EScottUtz, 05-16-2010 14:41:38
You might find one used in better shape ?
I had the one on my 720 D refaced be sure to keep the crown in it. Might take less then you think to clean it up ?
BushogPapa
05-16-2010 18:24:57
That wear is from not replacing the clutch-brake pad when it wears out..
I seems there should be a way to repair that with a ring of metal made for it...Sweat it on like a ring-gear is put on...
That would also repair many broken cluth-drums, too...
Ron..
