update on 4020 losing prime
I put a new lift pump on today and it pumped the filters full quickly with the lift lever. A crack of two injector lines and it started right up as usual. Ran most of the morning but I won't be able to use for a few days. We will see what that brings as I did not turn the tank valve off to see if it is going to drain back by the time we need it next. As quickly as it primed up, I am pretty confident that all were right about the lift pump. Thanks for the posts. Brian
