Haywood
I thought one of the plugs was wrong but I
Found this JD service bulletin on installation of the selector Valve installation in the top port for remotes off the right side.
Selector being turned in or out depending on what operation you want to run in. This S.B. eliminated a whole lot of questions and showed me how I will set it up when I get it all working.
This appears to be my configuration of plugs without the remotes installed. So these should be fine and preferrable. The rockshaft should work with the selector screwed out as long as the metering/throttle adjustments are set OK for rockshaft.
I will get everything set tomorrow and see what happens.
Thanks for the tips earlier.
Haywood
powr_trol service bulletin
Haywood
