Good day,
My 12 yr old son has a '66 JD 110. The tractor has never charged correctly. I recently found a wiring schematic on the net for a 110 (would attach but dont know how). I recently rewired the tractor to match the schematic. when I went to start the tractor, I switched the key to the 'run position' and the starter started cranking. I stopped that problem by disconnecting a wire between the GEN terminal on the regulator to the starter side of the solenoid, but now when I get it running, it does not want to shut off. I am assuming some type of backfeed.
I have two main questions:
The starter / generator has two posts on it. The schematic shows one wire connected to the starter solenoid and the other shows a wire going to the "f" terminal of the voltage regulator. The posts on the starter / generator are not labelled. Can anyone verify that I do have the starter / generator wired correctly?
Secondly, the voltage regulator that is on it has (4) posts:
BAT , GEN , F, GND.
The wiring schematic has the following posts labelled:
BAT, GEN, F, L.
I am not sure I have the correct regulator on it due to the GND vs. L. Can anyone tell me if the regulator with the GND will work?
Any help is greatly appreciated.
Thanks. Scott[/img]
BAT , GEN , F, GND.
BAT, GEN, F, L.
Thanks. Scott[/img]
