3 Point on a model 60
esfoder
Do any of you guys have a pic of a three point on a model 60??
Just got mine running and want to put the hitch on her??
Thanks
Dusty
801 hitch on a 1953 JD 60
Be aware that if you are going to mount a mounted plow, it will need a depth (gage) wheel to control depth..
You can improvise with that top-link and use any 3-point equipment...
I used an "Eye-bolt" with a couple very large washers in the spreader-bar and drew the slack out of it, once the implement was attached.. worked just fine...
Ron.
We had a similar sprocket on one of our John Deere's that was used to drive a chain to an attachment on a cultivator...believe it was either a fertilizer or insecticide box. Had one one each side of the tractor.
