Anonymous-0
hi, i have a 2840 thats has been a really good tractor and has never had any of the hydraulic problems people talk about until resently. at first the brakes would take a couple "pumps" to get firm then they would work fine, and now we lost power steering.. every now and then right after you start it it may turn left, but never right, and all the other hydraulics work fine, loader, 3 pt, and the brakes work fine after a couple pumps, we found a fluid leak from a blown gasket on the steering side cover kinda behind brake pedals if looked at from side, we fixed that via new gasket, then it started leaking were the steering column is bolted down, found the two front bolts came loose and every time you moved the steering wheel it would lift the coulumn up a little and leak hydralic oil. tighted the bolts back down and the leak stoped but still no power steering. im curious what is going on here. my dad was using it at the time and he said he thought he heard a pop, I think it could be the steering motor itself or the column, i dont understand much about how the system work but i would assume the seals are bad in the steering column. its almost like a rack and pinion system in a car right?? ANY thoughts, ideas or answers would be greatly aprrieciated!!!!!. by the way deere wanted a thousand dollars to rebuild the steering motor!!!!
