Its in the shop getting a set of new injectors (4 tested bad and the last 2 were almost bad) and I had them run a compression test on it. The foreman said they came out excellent and surprisingly close to each other (5 were 375 1 was 360). What are the normal ranges? I had them test the trans pump and it came out low on flow (<3gpm at pressure) so they are tossing one of them in as well. I'm also having them toss in a lift pump and a set of brakes on it while its in the shop getting the other stuff done. I don't have much other work planned for it right now. I am hoping with the new injectors it will run a lot smoother and stronger.
