Company Logo (800) 853-2651 Shop Now
JD 4020 24v alternator wiring
quake
01-24-2010 20:03:39
A friend of mine replaced the gererator with a one wire 24v alternator. It's only charging one battery. What I can't understand is if the alternator in grounded and only one battery is grounded how do you charge both batteries. Does anyone have a wiring diagram for this.
44 Diesel Tech
01-26-2010 17:07:55
 Re: JD 4020 24v alternator wiring in reply to quake, 01-24-2010 20:03:39
[quote="quake"](quoted from post at 01:17:15 01/27/10) I rewired the batteries and hooked it up like this.
Interesting, What are you doing about lights and gauges? To answer your question, one batt. must be bad.
This post was edited by 44 Diesel Tech at 17:11:10 01/26/10.
quake
01-26-2010 16:17:15
third party image
quake
01-26-2010 18:42:27
 Re: JD 4020 24v alternator wiring in reply to quake, 01-26-2010 16:17:15
Believe it or not a John Deere tech told me it would be no problem to hook up the lights and guages.this tractor has bouble lights on the front. I just looked a wiring diagram for the lights. He must have been talking about another 4020 :) This is real interesting how they use both batteries to run the 12v lights with what you call a floating ground. I can fix this problem but it's gonna hurt me brain. I have thought about insulating the alternator. It's up to the owner to decide.
quake
01-24-2010 21:46:05
That what I thought. It looks like you would have to have an isolated or insulated positive and negative. Thanks for the info.
buickanddeere
01-24-2010 20:43:37
Your buddy was guessing instead of purchasing a service manual instead of knowing. Now he is going to have to purchase another alternator which floats. Or repair the old generator. He didn't save any $$$ being cheap.
Bob
01-24-2010 20:08:13
WHY don't you get the proper 24 Volt alternator with floating ground?
The setup you have will be a NIGHTMARE to anyone who ever has to work on it and straight 24 Volts above ground is enough voltage to WELD with!
Tom 43
01-25-2010 04:42:02
 Re: JD 4020 24v alternator wiring in reply to Bob, 01-24-2010 20:08:13
Where does the term "floating ground" come from? The generator, starter, and regulator are all grounded to the positive terminal of the battery. They are grounded through dedicated wires and insulated from the frame. I have heard the "floating" term before and am curious as to its origin.
buickanddeere
01-25-2010 13:57:10
 Re: JD 4020 24v alternator wiring in reply to Tom 43, 01-25-2010 04:42:02
Because the 24V starter,generator and regulator make no reference to chassis to operate. They could be bolted to a 2X4 and operate just the same.
John T
01-25-2010 06:07:09
The term "floating ground" in this context means the Starter and Generator do not have either electrical terminal bonded to the case/frame as the case in most typical 6 or 12 volt tractor gennys and starters. The terminals exit the case/frame and are insulated from it. The genny is 24 volt and charges BOTH 12 volt batteries at once in series and the starter is 24 volts NOT electrically tied to case/frame.
PS this is for the 24 volt systems of course NOT if they were converted to 12 volts
John T
LarrySTN
01-25-2010 05:27:25
Tom43 On a 4020 24 volt system, the starter generator and regulator are NOT positive ground to the frame. The starter generator and regulator ALL have positive and negative connections and are isolated from the frame, thus they all have a "floating" ground. One battery has a connection from positive post to chassis while the other battery has a connection from the negative terminal to the chassis.
Today's Featured Article - What Price Enthusiasm? - by Anthony West. Quite frankly, for some time now restorers like myself have become more and more concerned about the rapid increase in the prices of old farm machines here in England. There is now a growing market for "As found" machines. Which as machines get rarer, has found the birth of a new industry....one of the "procurement agent". These agents appropriate as much old machinery as possible then inflate prices at auctions. So at what price enthiusiasm? We are now seeing poor machines which 3 years ago ma ... [Read Article]
Latest Ad: 4- D6 cat dozers and accessories [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
