1940 JD B - oil to rocker arms
doehmke
How do the rocker arms get lubricated on a 1940 B? There's no oil line from the oil pump through the head, like on later Bs. Does oil drop along and off the push rods? Anything else? I'm sure I've put everything together correctly, but am curious how this works.
Thanks,
Dan
The oil comes from the line on the governor housing to the valve cover. Inside the cover is a trough that drips on the rocker arms. Ron Mn.
