Hi,
just got done with my first split on a green tractor... and wanting some confirmation of what i suspect might be the problem, and how to go about fixing it.
Split the tractor between the transmission and clutch housing to replace a loose oil line, clamp and ended up with a newer transmission driven pump.
Got the tractor back together and started ... the hydraulics now work. But... the PTO doesn't turn when engaged.
Going back together, the PTO was able to turn the whole time, so thinking that the coupling (T30767) that's in the transmission housing fell off when splitting, and didn't realize it before it went back together.
Assuming that's the problem, then is it fixable by taking the PTO shaft out of the rear end, or is another split required? Can one get at it by taking the rockshaft housing off?
thanks!
thanks!
