I will try to give enough information.....
I have known about this problem for a couple years. The leak has gotten WAY worse, bad enough to turn the oil milky almost immediatly. There is no evidence of water in the exhaust, and no leaks anywhere on the outside of the engine.
This time after changing the old oil (which was milky), I filled the radiator.
The water/antifreeze went down to the bottom of the neck after running it for an hour.
I have been thinking about this, and reading on here about what it could be.
This B has been in the family for about 30 years, and no one has been in it except me since then. I have never had the head off before today.
I was convinced it was the pushrod tubes leaking, so off came the head. (2501R) There is no evidence of water in, or coming from the tubes. I looked the head over with out cleaning anything, and still couldnt see anything. I finally ran a cloth through the tubes and they are shiny and smooth, and the ends did not show any signs of leaking around the outside. I didnt have a special radiator cap so I could pressurize the system and watch for leaking in the tubes.
The head gasket that came off was a VIC-2-FOLD, copper side out. Couldnt see anything on it to warrant leaking across the holes in the gasket.
The only thing that I even found questionable was the drain hole on the back, bottom center of the head. It's the drain back hole from the rocker cover, which has a little bit of rusty look inside.
What to do.........
I am not prepared to spend all sorts of money getting everything sent out and tested and rebuilt. I am guessing there could be a crack in the head somewhere, the antifreeze has always been mixed 50/50, but it still could be cracked somewhere. I understand that sending the head out may be the only way out of this problem, as I have to get this leak fixed before I run it anymore. If thats the case, I'm gonna have to shove it outside and cover it till I can find nearby resources and cash.
I would again appreciate any and all experiences with similar problems. Would anyone out there still be convinced its the pushrod tubes?
Whatever your opinions on this, let me know. I dont plan on getting rid of this tractor, I got it from my Dad.
Thank you.
What to do.........
Thank you.
