Tx Jim
- Location
- Coyote Flats, Texas
On a 4020 24V starter that has been changed to 12V,does one have to change to 12v field coils along with armature? Starter just returned from repair shop.
Reason I asked is I'm working on a 4020 that cranks slow,has new batteries & cables and starter has a stud for ground cable. Batteries test 12.7V with engine not running and drop to 7V when starter button is applied. I'm looking for an amp meter to check amp draw.
I've never seen a ground stud on a 4020 12V starter as one normally grounds negative cable to frame or engine block.
Thanks,Jim
Thanks,Jim
