(quoted from post at 14:05:07 11/22/09) I'm hooking up a log splitter to a 3020--already have a loader that is connected through a third remote...2 options I think I have is to use one of the two remotes controlled by the operating levers and tie the lever open or...there is a single outlet above and to the right of the PTO shaft...could I use it with a close center valve on the splitter???
You are mostly correct Papa John 4... except for the part about the single outlet above and to the right of the PTO thingy. That is NOT an outlet, it is an INLET to sump only. Not pressure, it is a RETURN port. You will be doing NOTHING with that port whatsoever.
Therefore, you really only have ONE option...
Plug your 2 hoses from your splitter into one of your "free" dual remotes on the back of your tractor. Then, move the lever that corresponds with that valve to pressurize the oil going to the splitter valve. (You may have to "swap" your hoses around to get the desired outcome for splitter valve lever direction in case you plug them in backwards the first try.)
Your remote valve lever will need to stay in the "on" position, if you will. This is typically achieved by holding it with a rubber bungee in order to keep the valve from kicking back to neutral when a load is applied to it by the hydraulic back pressure that will be created when the cylinder is splitting wood.
Be 100% that your splitter valve is set up for CLOSED CENTER operation. Most all log splitter valves are OPEN CENTER valves.
Some can be changed by changing a plug in the side from being ported to being plugged off. You would buy this closed-center plug from your local hydraulics supplier, and naturally, for the brand and model of valve that you have (Examples: Cross, Gresen, Prince, etc. are all pretty popular names).
If you attempt to run your log splitter with an open center valve, you will cause major cavitation in your tractor's hydraulic system. You will hear it make some really bad noisy chattering sounds, which is the cavatiation occurring at the high pressure pump. If you hear that sound, STOP!!!! You have an OPEN CENTER splitter valve! To continue on and ignoring the hydraulic chattering would very quickly DESTROY your 3020's very expensive high pressure hydraulic pump! Not to mention, you would have a slow, irradic, and weaker operation of your splitter cylinder.
Anyhow, in lamens terms, look at it this way. In a "closed-center" hydraulic system, the pressurized fluid must "deadhead" in order for the pump to stay in "neutral" and not pump a high volume of fluid. In normal operation, when the remote hydraulic valves on the tractor are in neutral (no flow in either direction), the pressurized fluid from the pump is blocked off (at the valve) from returning to the tractor's transmission/hydraulic sump. This is normal, and this is good.
Now, when you hook your log splitter hoses up to the tractor, you now need a "new" spot for the fluid to "stop" at once you have tied the tractor's remote valve "open" (or "on") with a bungee. That new "stopping" spot will now have to be within the log splitter valve itself. If the valve stops the oil, then it is a "closed center" valve, and you have NO worries - happy splitting.
If the splitter valve allows the oil to circulate straight through it and back to sump, via the return hose (leading to the nasty chattering I was talking about earlier), then you have an open center valve and you must stop immediately.
Now, you must either change the splitter's control valve "plug" to a closed-center plug... OR change the entire splitter valve alltogether if it is not an adaptable valve. Be aware, many older open-center hydraulic valves were NOT able to be adaped to closed-center valves. There are also cheap modern valves on the market that cannot be "converted" either. Once you've installed your "closed-center" plug, or changed the entire valve to a "closed-center" valve, then you are all set. Happy Splitting!
I know, because I've done A LOT of this kind of thing...
P.S. That male nipple/port you speak of in the rear of the tractor is a return to sump. Nothing else. This is there only for two common things that would be used on a JD 3020. One is for the hydraulic trip/reset land plows. The other is for the return oil from hydraulic post pounders. Some hydraulic motor applications where there are seperate case drains would use this port as well (often found on hydraulic blowers, air seeders, and the like - as "Bob" has already pointed out).
I have one of those large volume "return to sump" setups on a JD 4020 and on a JD 2630. Our post pounder uses a 3/4" dia return hose for a fast release of hydraulic fluid from the I-beam lift cylinder. It has a single acting cylinder that raises the I-beam and then it "dumps" the oil directly back to sump of the tractor whenever the remote pounder valve is activated to release the I-beam to drop.
Hope you are understanding all this stuff. (Actually, from what you posted, I'm pretty sure you knew most all of this before you posted.) I get the feeling you were just looking for confirmation to be certain before you accidentally schmucked up anything. Well, you are right on track, and now you know what that pesky male nipple sticking out the back of your tractor is for too! LOL.
Happy Splitting & have a Happy Thanksgiving!
~ AJ
