alan jacquin
New User
Hydraulic functions either function well, chatter or now quit all together, randomly as to what rpm or how long I have been running the engine, but until today(after adding fresh-er-er fluid) decided to actually quit.
Ok...so now there is no fluid escaping the outlet side of the transmission case with the tractor running(see attached pic to verify correct port), but the belly filter is full of fluid. Which makes me believe the possible causes are intake screen(checked multiple times), Transmission pump, belly filter(also checked multiple times), or the oil filter relief valve above the the belly filter.
I am hoping the oil bypass is the problem rather than the trans. pump, but don't know how to properly remove the pin and spring without damaging anything. The service manual says to remove the valve assembly, then drive the spring pins out; does this mean I can grab the spring pins, twist and pull without messing something up?
Alright, quick reminder from the prior thread....but shortened. Checked the inlet screen filter, the main belly filter, the stroke control valve+filter, and more. All components are clean and don't reveal any visual signs of wear.
