us b brakes
rytre
On the round cast brake drum there are six dome headed round rivets that are visible from the outside. these rivets are loose. How do I go about tightening these? These rivets hold the main shaft that goes through the brake assembly to the brake drum. thanks Marc
You should be able to rig a support to back up the rivet heads inside the drum, then re-peen them. If this doesn't work, you will have to replace the rivets. You should be able to get them from Deere or a good fastener supply.
Paul
