I got the 630 running after two years of rebuild and lots of new parts including new aftermarket gauges. The ammeter gauge jumps around a lot but does show a good charge. I have turned the 2-brush generator commutator and cleaned between sections and changed the voltage regulator with a new one I had. The generator brushes are good and the bearings are good. I'm not sure about the fields or armature since I have no way to test them but like I mentioned, it does charge okay. I am wondering if it is the generator or cheap aftermarket ammeter that is making the ammeter so jumpy. I didn't like the way the one terminal on the ammeter wouldn't tighten. Also, I wonder if there is an internal capacitor in the better ammeters to keep the needle from being so jumpy.
Thanks for any ideas you may have.
