Planedriver
My 2010 gas row crop with a narrow front end is leaking from the steering motor. I know one line will need to be replaced but I'm also sure it's leaking from the lower seal. The steering functions flawlessly so I'm wondering if I need to tear the whole thing down or if there is a shortcut that one of you guys might know from experience. I really don't want to take the whole thing off for a $10.00 seal.
Finally. Even though the steering works fine. Should I replace the o rings in the pistons because they may be blowing by building pressure and causing the lower seal to fail?
