51 b Roll-o-Matic
[email protected]
I've done a little more research on my tire wear issue. My front tires are 2 inches toed in on the front. I installed new wheel bearings and inspected spindles and everything internal. It all looks great. The hubs do not turn off center and there is no reason to assume a problem. Is there a way to do an alignment to one of these? I'm sure someone must have come up against this problem before? Thoughts????
If the bushings are not worn badly, with a lot of slop, then there must be a part that is "sprung", to give it a "toe-in"...
Ron.
It sounds like the spindles are sprung or someone replaced them at some time with the incorrect ones. Check out the part #s on them.
Sprung/bent rollomatic knuckle(s). Not a lot you can do about it, except swap out the whole thing. Be cheaper than swapping out the knuckles. Then you can sell the other rollomatic.
