loneranger27
Hi, I am restoring my grandfathers unstyled A. I have a question. Attached to the shifter cover there is a plat plate that has a cut out for the shifter to pass through in the trans. JD calls this a gear shift interlock # A239R when I move the shifter from up and down the bottom of the shifter hits this interlock. If i pull out on the shift lever then it passes through easily. I guess my question is am I supposed to pull out on shifter to move lever between 1 and 2nd gear or do I need to make some adjustment?
Your help is appreciated.
thanks
johnny
thanks
johnny
