There must FIRST voltage getting to the switches BAT input terminal so the lights and ignition etc can work. Then as Rob points out, the switch itself needs to work. I theres no lights or no power to the ignition either nor does the gauge work Id suspect the voltage source that feeds the switches BAT input terminal is bad/open. (See below, the wire that feeds it comes from the ammeters output and the ammeters input comes from a wire down to starter (can get cut/burned open) or else direct from battery (may have been jury rigged in past)
ALSO,,,,,CHECK BATTERY CABLES N CONNECTIONS AND ESPECIALLY THE GROUIND
The voltage source TO the switches BAT input terminal is derived EITHER from the Load (NOT battery/starter) terminal on the (Insure BOTH ammeter terminals have hot battery voltage) ammeter, or else the LOAD terminal on a 4 terminal Voltage Regulator
SO FIRST OFF INSURE THERES HOT BATTERY VOLTAGE ON BOTH SIDES OF THE AMMETER AND ON THE BAT INPUT TERMINAL ON THE SWITCH
If theres no volatge getting to the switch, trace back n see where it gets lost. If there is voltage to the switch then see if the switch is bad i.e. isnt sending hot voltage to lights or ignition when turned ON
Next if theres no voltage at switches BAT input, see if theres a good wire from the Load side of ammeter or L terminal if you have a 4 terminal Voltage Regulator,,,,,,If thats good, see if theres hot battery voltage on BOTH sides of ammeter???? IF NOT the feed wire which supplies hot battery voltage to the ammeters Supply input terminal is bad.........
The input to the supply side if the ammeter may be fed from the starter where the big battery cable attaches CHECK THAT WIRE !!!!!!!!!! Or it may be fed directly from the batteries hot ungrounded post
Look at the wiring diagram and trace for a good hot battery feed from the starter to ammeter,,, out of ammeter to switches input,, AND ID SUSPECT THE WIRES BAD FROM STARTER UP TO AMMETER OR FROM AMMETER TO SWITCH if absolutely nothing works. HOWEVER if some things work (like lights or igntion or fuel gauge) then Id suspect the switch like Rob was talking about
ONE FINAL THOUGHT Id check ALLLLLLLLL battery n ground connections cuz if theres a bad battery connection or a bad ground NOTHING will work.....
John T
Wiring Diagram
