2 cylinder drawbar question
Scott 730
Location
EC MN
I recently purchased a drawbar on Evilbay that I think was listed incorrectly. It measures 1 1/8" X 2" X about 49 1/2" long. It is an offset bar, with the bend in it. What does it fit??? It was represented as from a 70 or 720 in the listing. My 730 drawbar is 1 1/4 X 2 1/2".
I would like to know what I was sold, so I can attempt to return it and get my money back. What is the best way to deal with this problem???? Thanks.
If it has a upstep on the end, it is probably a common row crop style swinging drawbar, R 21331 R. You can go download some parts catalogs for free from jdparts.com and do some research, but if he said it was for a 70 or 720, it was probably truthful. Not sure that that drawbar was used on the 730.
I know the 730 didn't have the offset drawbar, but if he said it was for a 70 or 720 it should still be the same same size bar stock as a 730, right??
The drawbar changed at serial # 7214899 on the 720 tractors and ran thru the 730"s. The one you bought is probably for the 70 & early 720"s . If you need a new one I reproduce it. 410-643-2899
My bad. I should have checked my parts book first. It looks like 720's prior to #721490 used the offset drawbar, and also use a different drawbar support assembly. :(
