Hello,
I have a 3010 RC early s/n 1010. The brake valve must have had moister in it an froze, cracking the housing along the bottom. There was a weld along this crack but it still leaks.
I found a valve off a 3020, the casting is slightly different in that the ports that go to the brakes are bigger and come straight off the back, instead of coming outta of the valve at an angle.
I figured it wouldn't be a problem just smaller lines. So I drilled the plugs and threaded in the smaller fittings into the outlet ports.
Now when I start the tractor I can't budge the pedals.
Any ideas?
Thanks,
Mike
Any ideas?
Thanks,
Mike
