I've got to install an alternator on one of these tomorrow, I think he's got a service manual for it, but not sure if there is a wiring diagram in it. Just a favor for a good friends dad, I've replaced some faulty wiring on this one before, but it's been awhile, he finally got an alternator for it, wants me to install it, but he removed the old one for the core charge on the new one, so not taking it apart, has to be a typical 12 volt set up, I assume from the factory for a 2020, just want to make sure I've got everything connected properly, as I did not take the old one off, usually it's plug and play with most of these and if you took it off, you remember the connections or have marked same. Kind of a parts replacer on this one as I never remember the typical 12 volt alternator circuits, and do not want to short it out, simple enough to work on, best to make sure the circuits are correct before firing it back up again, he's been dealing with a draw down on the battery, old one was not charging last I checked with a meter, not sure what else could be a problem, worst case I'll wait until I can find a wiring diagram.
