rytre
I just put the original tappet cover/ govenor line back on the tractor with new rubber seals on each end. How tight should the connectors be on either end of the line. thanks again Marc
They don't need to be all that tight as the rubber squeezes down to seal them, so don't bear down on them.
Thanks very much for the quick reply Mike. That's kind of what I was thinking but was not sure. Marc
its always easier to tighten it up a little bit more if need be than to back off after you've done to much.
