update 70 points
johndeereman
well thanks for all your help i changed the coil i cleaned the distributor with wd-40 and went to napa and bought a brand new set of points fired her right up run her 3 1/2 hours baling second cutting run like a champ
what part of the distributor did you clean with wd40? Isnt wd40 oily? Oil on the points will make them burn up prematurely. bill m.
