Hello,
Thank you for important info in regards to post titled: DLTX 34 only runs with choke 1/2 open. I set the idle needle (1 to 1 1/4) and load needle (3/4 to 1) as mention in "discussion". Tractor failed to start, Pretty soon I'm going to order the drill bits from roberts carburetor to drill out passages in the carb..This may be a dumb question but from what you know, When I attempt to do this (drill out carb), will I have to also re thread (tap) new threads in the wholes I drill out. (Will the recomended drill bits sizes require this?) . I'm going to order drillbit sizes 40 and 53 for dltx 34 carb.
Thanks for your help,
