John (Ohio)
I purchased a 1959 630 and I am in need of your assistance. Originally I thought the thermostat was sticking and causing the temperature to come up (I shut it down when it got above 200*F). When I opened it up there wasn't a thermostat in it. I then thought maybe the water pump impeller was slipping, but I pulled it out today and it was tight and appears to be in good shape. I checked for blockage in the lower hose and pipe and it was clear. I checked the upper pipe and it too was clear. The radiator and block don't appear to be clogged either. The radiator fins are clean and I can see through the radiator fins so I think it is ok. The radiator does have some signs that maybe the fan has gotten into it a some point but it is watertight. The fan belt is tight and doesn't appear to be slipping. It did run longer before heating up without the front hood on which makes me wonder about airflow or the fan itself. I am open to suggestions as to what to check next. This is my first Deere and don't want to mess it up. Thank you in advance for any advice you may have.
John (Ohio)
John (Ohio)
