I have replaced the clutch, pressure plate, throw out bearing, and pilot bearing. I found a dealer, after calling 5, that would let me measure the JD227 pressure plate tool and made my own. I adjusted all of the pressure plate fingers to +/- .002" of each other and the tool. With all of this, I still can't get the clutch to release all the way. I can force the transmission into 1st with some finesse, but non of the other gears will go with out shutting off the engine first. I have checked the range and speed shifters for proper adjustment. When mating the tractor back together after being split for the clutch (twice) the tractor slides together like it was on a rail. No having to pull it in (I know your not supposed to), no shoving, just a little jockeying around with the jacks and a small push. After all of that...ANY SUGGESTIONS?
