1020ag/300ind
sherburne
What tractors are like or very similar to 1020ag/300ind bare tractor? Thanks.
I know the 1020 ended early 70's. I was looking at a 1994 brochure and noticed a 2100 series(2135?) that looked almost identical with different sheet metal.
2100 isn't even a Deere tractor - it's made for Deere by Zetor.
820, 830, 1020, and 300 are all close to the same tractors. If diesel they all use 152 c.i. three-cylinder engines and if gas they all use 135 c.i. engines. As far as I know, the German 820s and 830s were not offered with gas engines.
The hydraulics can differ a bit with the different series. Some of the German tractors use open-center systems. The 1020s use closed-center but very small German pumps. Also not that some 1020s also use open-center steering along with the closed-center system. The industrial 300s came with the small German pumps or the larger U.S. 2.4 cubic inch pumps.
The later 2150 and 2155 tractors also use three-cylinder diesels but they are 179 cubic inches, not 152.
