Well, that was a lot of work for nothing. I got the 2010 all back together after getting the rollers back on the shifting forks and changing the clutch and pressure plate. The tractor acts as though the clutch is not disengaging. But I removed the access plates and crawled underneath. The clutch is working. I bypassed the neutral safety switch and started the tractor in gear. Something in the differential area seems to be slipping because even when started in gear the tractor won't move forward or reverse. It tries to move, but every couple of seconds something slightly grinds and the tractor rolls slightly (fractions of and inch) and rolls back the same amount. I can actually start he tractor in gear and with the clutch out and it acts as though I have the clutch in. I was going to pull the brake covers off this morning and see what is going on with the final drives. ANY help would be appreciated. Thinking of salvaging it out.
