Re: Where do I get this type of D-Ring:
showcrop
11-11-2023 10:21:15
On Ebay for $33.21
paul
11-12-2023 17:43:06
 Re: Where do I get this type of D-Ring: in reply to showcrop, 11-11-2023 10:21:15
This is a broken thread in classic view so many of us dont know what you are referring to.
If I recall, it might have been the old bolt on plow Clovis for an Oliver plow?
300guy
11-11-2023 17:30:34
If you are looking for the twisted clevis used to pull a plow, they are available at Tractor Supply. I just saw them the other day when I was in the store.
caterpillar guy
11-11-2023 15:00:25
well I can't read minds nor smoke signals. So A picture would do wonders for it. Though most truck supply houses trailer repair places and truck dealers will have them with the curl that you weld them on with. The curl is a piec of steel that fitsd over the flat side of the D ring and then welds to whatever you are putting them on so they can be moved from side to side.
