Old IH 249 corn planter
Are there any videos on how to setup and go over the older planters like an IH 249 corn planter , I want to plant corn with it this yr but it was rigged for planting pumpkins , guy took a corn seed plate and bored holes into it then put fiberglass over the other holes , I have other plates for it for corn
Not that I can think of. Do you have a manual? There's a few for sale on eBay & plenty of other places that do repro's & sell originals. Not only does a manual tell you what settings do what, but it will also show you all the seed plate specs so you can get the right ones for the job. Most plates are easy to source & they can be had in original cast or newer plastic plates which are still in production. If you do a search for Duffield Equipment out of MD, you'll find quite a few parts for your planter & Mike is quite knowledgeable about finding parts & may be of some help for setup.
Good luck!
Mike
We put the pumpkin seeds in the fertilizer unit hoppers with peas ,sunflowers , etc. feed the out with the fertilizer just what did to get around not having seed plates
Heres an eBay to a manual ,good luck
https://www.ebay.com/itm/224487616843?hash=item344481314b:g:NbwAAOSwNXpcjgbJ&amdata=enc%3AAQAHAAAAsDzcce%2B5a14w9%2BtRL2xLeiGTQ3d%2Bhm8k9IxfSb3fhNFOlrk9PDTWyb4%2BJcxD0CVcfwOtNF0l6FhVM1TSGHqHpasSzQ%2B7aULG%2FSgs9PjWC9QQ%2B716J5NKZtAKdBJhw3vgYMUVC7SZg0dIOQ0E4Eix%2FInIduYHbWUY8j0RfdvXFOzRSnRTHrVYUSqX6gWLAUMurRT4R0PkiXt7iP4q9KBAFzCuiaSBvG4AGQUOcxmJQKyv%7Ctkp%3ABk9SR9jH4Mi-YQ
