Dearborn two bottom plow share broken
Wanted to know where to get one new moldboard for this okd
Dearborn plow , it makes a mess of the field when plowing
sod
What model of DEARBORN PLOW? I cannot read the p/n from your photo. 10-??? Do you still have the broken piece? In the old days farmers would just weld it back on. The Amish and Mennonites often have a Blacksmith who can do the job. You need to determine what size moldboard you have if you want to buy new. DEARBORN MODEL number will define what size of plow you have. Most are 14, designated with a 10 prefix code and then the number. The early DEARBORN models use different parts and are NLA. The model numbers for the early DEARBORN MOLDBOARD PLOWS are 10-1; 10-8; and 10-10 mostly. The DEARBORN ECONOMY PLOWS, 10-151 is a 10; 10-152 is a 12; and 10-156 is a 14. THe ECONOMY PLOW was a much better design and parts are available today but I don't think they make 10 and 12 inch styles anymore. The early DEARBORN plow can also be ID'd by the open A-Frame where as the ECONOMY PLOW had the solid A-Frame. DEARBORN moldboards had their diamond logo <DMC> stamp on the back with the moldboard part number. The 14 p/n is 104419. You measure the plow size with a tape measure across the width of the frame from outside to inside of frame. You don't measure the moldboard nor the plow share. NEW parts can be found at OSMUNDSONS or HERSCHEL PARTS INC. SPOILER ALERT: You might balk when you see the prices. Might be able to find another used plow for the same price.
DEARBORN MOLDBOARD PLOW, MODEL 10-8:
DEARBORN ECONOMY PLOW, MODEL 10-156:
*DEARBORN ECONOMY Plows offered optional 3rd Beams for making a 2-Bottom low into a 3-Bottom Plow.
Tim Daley(MI)
Do you have the broken section wing ?
If you cant find one
Weld it back on
I welded the old hillside plow we got , mold boards were fractured.
Could not find the part sucks because I was going to do that if I found it, maybe I could bolt a steel piece on there and bend it dont know if it will work or not
