Company Logo (800) 853-2651 Shop Now
630 John Deere disc or Krause disc
williaada
11-24-2022 07:58:45
Will be using a 4320 JD to pull a 630 or a Krause disc. Looking to work up about 80 acres. What disc will serve me better. Krause is about 4k and the 630 will be about 2.3k need to replace one broken disc. Thinking I will be going about 5.5-6 mph.
Appreciate the responses.
Leroy
11-25-2022 06:35:34
 Re: 630 John Deere disc or Krause disc in reply to williaada, 11-24-2022 07:58:45
Is Krause a reginal brand? Only place I have ever heard of that make is here on this site. Never heard of it here in Ohio. But I only had and used smaller older machinery.
Texasmark
11-25-2022 06:52:23
 Re: 630 John Deere disc or Krause disc in reply to Leroy, 11-25-2022 06:35:34
I buy used implements and on a couple of occasions bought Krause. My experience is that they are very heavy duty and pull hard.
Leroy
11-25-2022 07:09:54
 Re: 630 John Deere disc or Krause disc in reply to Texasmark, 11-25-2022 06:52:23
Possibly being that heavy duty is why not around here. My biggest tractor when I was farming was a Ford 5000.
caterpillar guy
11-24-2022 16:18:16
I tend to shy away from Krause tillage pieces. they always seem to have a bent leg at the wheel on one side or the other. Don't know if it is abuse or just not heavy enough for the job. I would lean towards a sunflower disk, you would not be sorry. Heavy and will work ground in a couple passes fit to plant on if needed.
DeltaRed
11-24-2022 13:05:24
That 4320 will easily handle 16 ft. Krause makes good disk.
Brendon-KS
11-24-2022 08:52:41
Krause makes good disks - you see a lot of them here in central Kansas. (They're made right here in Hutchinson, KS. ) There are many different models out there, some relatively light on up to super heavy. A lighter weight 18-ish footer or a heavier 15 ft would match your tractor well if you have average conditions.
williaada
11-24-2022 09:12:03
 Re: 630 John Deere disc or Krause disc in reply to Brendon-KS, 11-24-2022 08:52:41
Would a 955a be sized correctly for the 4320?
Brendon-KS
11-24-2022 18:31:39
 Re: 630 John Deere disc or Krause disc in reply to williaada, 11-24-2022 09:12:03
From what I can tell a 955A is nearly 25 feet wide which would be too much for your tractor.
VicS
11-24-2022 18:51:20
 Re: 630 John Deere disc or Krause disc in reply to Brendon-KS, 11-24-2022 18:31:39
It would just need duals
Today's Featured Article - Introduction to the Gibson Model D - by Brandon Burnett. The Gibson Manufacturing Corporation was founded 1946 by Wilber Gibson. The Gibson tractors were made from around 1948 to 1952. The picture shown here is of a 1948 Gibson model D. If you notice, this tractor is driven with a lever. You could get a attachment to convert it to a steering wheel. ... [Read Article]
Latest Ad: 5 segment weights am4493. They weigh around 70# [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
