Johnnypopper
- Location
- Michigan
I am doing some off-season maintenance on my John Deere Model 660 Hay Rake. When I look inside the gearcase through the cap at the end of the output shaft, the lube looks white in color. I think it has a lot of water in it and I would like to replace the lube with new lube. The Owner's Manual calls for multi-Purpose lithium grease to be used in the gearcase. Pumping new lube in will be no problem, but I need to get the old lube out first. It looks like I have to remove the 6 cap screws and pull the input shaft assembly out of the gearcase in order to get inside and clean out the old lube. Has anyone done this before, and if so, is there anything I have to look out for? Will anything inside fall out of place and be hard to put back together? I would appreciate any suggestions you may have. Thank You
