Axle snowblower vs chain driven
Bj60land
New User
Hey all! Im looking at getting an old snowblower for my Case 540 and found 2 interesting SB, both 6' wide but one has the auger driven by an axle (differential type like on a pickup truck), and the other one is chain driven. The axle one is way cheaper but Im wondering how these perform and how reliable they are ? I assume as its an axle it must be pretty tough but at the same time they dont make them that way nowadays must be a reason ? Anyone here got some experience with the axle type or both and can tell me the pros and cons ? Thanks guys !
Sure would like to see a picture of what you call axle driven. My 48 2 stage is directly driven from a gear box. Most chain drives I've seen, have a sprocket on the end of the auger but still use a gear box and shaft to drive the chain. Are they both 2 stage?
No experience with axle drive, but to me anything ground drive that is expected to work on snow and ice isn't going to work.
I've never come across a ground drive snow blower, all are full PTO in these parts.
Yes both are 2 stages. By axle I mean the auger is driven by a differential in the center of the SB. The PTO shaft drive the fan and goes straight into the differential, with the auger on both side of it. Only cons I can see is that because of the differential housing in the middle, it might reduce snow intake and create more restrictions as it will compress on snow going thru a snow bank. Heres a picture of the kind of SB im talking about.
I had same thought you do and there is a reason anything new isn't made that way.
The problem I see if it is truly a differential is if taking a half cut the one side with the load stops then the easy one turns. I would hold one side then try turning one side and see if it is a true differential. If so I would let it slid by. get the one with a chain.
That would not be a differential in that application. J.ust a right-angle drive so both sides turn in the same direction. Mine is chain drive so I can't comment on how well it will work. Reason? Chain drive would be a lower cost to manufacture.
As others say, that should be just a gearbox, not a differential. Wouldnt work if it were a differential.
I assume it costs more for a big gearbox like that. With chain drive they can use a smaller gearbox cheaper. Is why that isnt done any more? Never seen one of those, so cant say how it would work.
Well it's probably like tillers...used to be worm drive with cast iron housings. Then the economists took over and it became chain drive with 2 pieces of stamped steel.....they tried that with riding mower front axles.....that was a total flop and only lasted a couple of years.
I cannot see that working in heavy snow without pluging, Perhaps for snow 6 or less might work. But not in 2 feet of snow. Did not even realize they made something like that. Back on the farm neighbor friend reletave would blow me out with I am guessing a 150 HP front wheel assist tractor and I would see him setting with all 4 wheels spinning trying to push into the snow and I do know his was a chain drive. I cannot see that one with the obstruction in the middle working here.
