Little genius 2 bottom plow
GaryOld
New User
I recently bought a IH Little Genius 2 bottom plow and I need to replace all 3 tires . Could someone tell me where I mite be able to get the correct tires for that . I live in Central Illinois if that helps . Thank you all for the help
This post was edited by GaryOld on 11/02/2022 at 06:57 am.
Do you want show piece tires or work tires? For work you can find used tires of close enough to cottrct show piece tires to work. Foe aused tail wheel tire go to a place that works with boat trailers and get a 4:80x12 is worn too much from road travel to use on road but would be good for years on plow and size is same as what would be sold new. Also does it have 15 inch or 16 inch wheels? A lot of good tires that will work there, for use does not have to be exact size or type and hundreds of dollars cheaper that new show piece tires,
Yeah it depends on what you want but I agree with using any old tire that will fit. Doesn't cost much and getting the most life from a tire has to be a good thing?? The guy that I got my plow from cut a tire and slipped it over the steel wheel for some reason. I don't think I would do that but as far as the traction lift working used tires seam to work. If you want to show off then Implement tread on backwards are what you need>
What is the value of a Little Genius. I have one i should be passing on, as i recall its on steel. Also have a couple sets of shears.
We just had straight highway passenger tires on our 2 John Deer 52 plows ans an AC 2 bottom trail type and no traction problems, Both have been gone for over 50 years now.
