David Bradley 75 Spreader Chain Size
Joe Disanza
New User
Hello
I need the chain that turns the last paddles at the very end of the spreader. Does anyone know what that size is. The chain links apparently have a number stamped on them but unfortunately the chain is lost so I have no reference.
Thanks
(quoted from post at 16:24:42 11/03/22) Hello
Thanks
There's a steel detachable chain chart by dimensions at the link below.
Measure the width of the sprocket teeth and the distance between teeth at the level the center of the chain links would run and you should be able to figure it out.
https://www.usarollerchain.com/Steel-Detachable-Chains-s/5051.htm
