David Bradley 75 Spreader Chain Size
Joe Disanza
New User
Hello
I need the chain that turns the last paddles at the very end of the spreader. Does anyone know what that size is. The chain links apparently have a number stamped on them but unfortunately the chain is lost so I have no reference.
Thanks
It is probably one of the 4 2050 ,2060,50,60 the only difference is the length of the link. the 20's are twice the length of the 50 or 60 links. If you sprockets are a long looking pitch like about an inch or just a bit over from center to center then it is a 20 something chain. IF you look in a search you will see what I am saying. It could also be heavier than 60 or 2060 like 80. I believe 50 is a half inch pitch and 60 is a bit longer maybe 5/8th's .
It will be the flat steel type and not a roller chain as other poster listed roller chaib sizes.
Yes cat guy, take the last number, 50 over 80 and that's a 5/8 length link, the 40 over 80 in a 1/2 inch link, and so on,for roller chain!
