Update on the spike tooth harrow
300guy
Well I have found some time to try to make some holders. Thanks to the suggestion of using tubing turned out to be the best method. See the picture. I made one prototype using a round rod and then made the square tubing one. I cut the tubing at a seam and then widened it out so the tooth would go through and welded a bolt on top to seal the seam back.
