Any old reman parts being made
For old combines like pull behind IH 76 or a self propelled 203 combine? Any older cheap small combines with parts being made? TIA
There are a lot of parts some used for the older Deere and Gleaner combines. Don't know about the others. Those were the most plentiful around here in the day. With Gleaner giving Deere a run for the money. This would be in Mid MI.
(quoted from post at 10:04:55 10/14/22) or a self propelled 203 combine?
I have (2) 203's. One runs one is parts...
I'm at the east end of IA, a few miles from the river.
Don't know where you are but you can buy bigger combines thant that for about the same money with 4and 6 row heads and 13-18 foot heads for wheat or beans if you get a flex head. 7720's got pretty cheap compared to smaller models like 4420's or 3300's. Both sell for close to the same money and a lot more machine.
Ok good to know. Its just about 3 acres I have in mind so I didnt have something to big on mind. However to quote Hannibal Smith Overkill is underrated
Like Catguy said, change your search to a Gleaner. Good parts support from AGCO as well as aftermarket. That's what AGCO means, Allis Gleaner Corporation.
As mentioned, pretty much need 2 machines if you want to actually depend on that age machine for harvest. One for parts. On three acres I can see your desire for an old pull type, and I would go that route. Go through it well and get bearings and chains up to snuff and good to go. Takes effort that first time through it.... then good to go.
Also as mentioned, the Gleaner line is pretty well supported in the self propelled K, F, and bigger lines. The K was/ is converted into a handy plot planter with a lot of them out there on research farms, and so has kept up the parts support on them more than most. Gleaner was considered the simpler, fix yourself, machine at the time, and has been able to keeps parts coming to us old wrench farmers.
JD 6600 and up there were so many, there are still parts and old machines around yet. There were a lot of 4400 also, but support for them has dried up a bit, as they were the small machine and less and Lees use one, with 6600 and 7700 sizes priced almost the same used.
In todays world I dont know if there are parts for anything, 60 years old or 6 months old...... :(
Paul
