ford moldboard plow parts
Does anyone have a parts source for a ford 2 bottom plow ? the frogs ,moldboard,shins ok all i need are the shares. The old plow still has a tag on it with the serial number. Agri supply sells a share that looks good but don"t know if bolt holes will line up .
Ford plow tells us about nothing. Is it the blade type share commonly called a throwaway share or a cast forged share I am gussing the first type but hard to tell with your description. The blade type should be avaible several places while the other id not very avaible. Now check for numbers on back side of your old share, need a good wire brush to clean dirt and rust off. Once you get the numbers it should tell you if share will fit. I don't know about that place they at times will have a chart that gives hole spacing so you can go by that if the old share is from an out of bussiness share maker to figure out what you need. They should be able to give hole spacing if not listed if you call them. My Ford plow takes the forged style share.
If it has the replaceable points. Then look for an Osmundson dealer they should be able to supply you with a new one or two. Osmundson has been a big manufacturer of tillage parts for many years now. They used to be the supplier for TSC.
Need more info. I've got a Dearborn 2 bottom with Oliver Radex bottoms. Simple enough to find those parts. The later Ford plows
were just Olivers painted blue.
Thanks for this info I have never heard of this company. They have quite an inventory of parts. Almost finished fall plowing and I,ll take them apart and get news shares.
