Sickle mower identification
Or a very detailed description. :)
New users cant post pics until they make 5-10 messages, that keeps spam postings down around here.......
Sometimes picture posting just doesnt work well, and works great the next day. A few gremlins get loose in the software......
Good luck!
Paul
(quoted from post at 10:45:19 09/14/22) I m trying to upload a photo but it keeps saying it is not allowed for some reason
Not always, but in many cases new users have to have 5 or more posts on record before the site lets them post pictures (or links), due to site spam filters. Another option is to go down to the Site Comments Forum and ask YT Support for permission to post prior to that. You can try going down to the Test Forum and making several posts there to get your post count up, trying to attach your pictures to each post. That may work after you make several posts. Then make your post here again. It may not work immediately after you get past the 5 posts, if not, you might try logging out and back in at that point. There is a size limit as well, I think it is a total of 7mb per post (be it one picture or the total of several). Some pictures (often taken with phones), are too large and have to be reduced before they will post.
I was told it was a Oliver brand it was painted green before I bought it. It s a 7 bar length the belt sits on 2 pulleys only. One larger one and smaller one by the bar. On the rear of it it has 1 large spring that hooks up from a bracket to a lower main shaft .
If it is an Oliver, I'd guess 415, but don't know without seeing it. Scroll down to the test forum and make some random posts until
you have enough to be able to post pictures.
Looks like an Oliver 351 sickle mower to me. But someone else
might know better. Oliver had some wacky numbering with their
sickle mowers. The 351 was, I think, a pitmanless one, while
similar 356 had a pitman... I think?
Google 'Oliver 351 Mower' - lots of pictures to compare.
I can't remember which style of guards/sections Oliver mowers
used, but it's one of the common ones - aftermarket parts
definitely available.
